Posted by chadd on April 25, 2009 at 22:41:39 from (4.142.198.55):
Well, I tore into our 1940 Farmall M today. It had 60 psi on cylinder 3 and 80 on the remaining cylinders. The head gasket was blown out between 3 and 4. The problem is that cylinder 3 also has at least 3 or 4 sets of corrosion grooves where the piston had been sitting in one spot for a long time with the valves open. It also appears to show evidence of discoloration of the metal, but it could also be rust damage. 2 and 4 have less pronounced grooves as well. Three of 4 pistons are covered with a blanket of prickly black carbon (burning oil?). The grooves on cylinder 3 are deep and easily catch your fingernail. All 4 bores have no remnants of the crosshatching on the cylinder sleeves. Additionally, I can wiggle the pistons in the bore at least 1/16 inch if not more. I was wondering about the following: 1) Does the above sound like grounds for a rebuild? (just want to make sure I am not being overly fussy; I don't want to part with more money than I need to) It is a work tractor, so it needs to be dependable.
2)It has 4 inch thin wall sleeves with what appear to be original aluminum IH firecraters installed under a 6336-DD Kerosene head. Can I still get a set like this (along with all of the gaskets, pre-overbored 4" I.D. sleeves, mains etc. for an inframe, where is the best place to get them, and what will the damage (to my wallet) be? 3)Is there anything I should know or check to make sure I don't rebuild it and wreck new parts? 4)It overheated idling for 15 minutes on a 70 deg day in neutral last year, which triggered the head gasket failure. I since found out that there was not thermostat installed, so it definitely wasn't the problem. The radiator and hoses are all new and the water pump belt was new and properly tensioned. It has no coolant ending up in where it doesn't belong, so I am wondering if anyone has an idea what would have caused such a severe overheat. Only thing that springs to mind is water pump. I just don't want to repeat this incident again in a year.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
