Last year on my 2606 with 18 gal tank still on the tractor. Poured 2 gals of muratic acid into the bottom. Let sit for a few hours full strength since that was where most of the rust was. Filled it up with water(just don't let the acid splash on you which is why the proper acid mixing method is to pour acid into water but I was usning a funnel anyway so no problem). Let it soak for a day. Muratic acid will flash rust very quickly. Used a garden hose to drain the tank over to a cedar tree I wanted to kill. Didn't kill it. Found some phosporic acid stuff at home depot. Put in a quart or whatever it was and rest water. Let sit another day. Sprayed it down with wd-40 water displacement to give it an oil coating. Problem is that there is a baffle just to the back edge of the filler hole. I couldn't get to that area nor could I spray wd-40 behind it.
Still getting a little rust this year. Under the tank I put a tee. Going straight down was a 4" piece of pipe for a drip leg to catch any rust. Out the side of the tee was a nipple going to ball valve and then on the sediment bulb (those sediment bulb valves don't always shut it off tight) I see a tiny bit of rust in the sediment bowl and once or twice, I've unscrewed the cap on the drip leg to clean out any rust.
I had put a couple wraps of window screen on the nipple (twisted a piece of wire to hold it) that screws into the tank to catch any rust and later removed it. I need to put one back in next time I have it apart. Some people put a piece of plastic/rubber hose on the nipple about an 1/2" to 1" long so it sticks up into the tank to keep the crud on the bottom of the tank from flowing in.
Just did a gas tank for the roto tiller this weekend. Mostly a varnish problem but some rust. Used Phosphoric acid (Behr concrete etcher 991-N in a grey jug, 45% acid solution, $20 for a gal at home cheapo)(Home cheapo had a gal of Klean-strip concrete etcher for $15 a gal but it has a 30 to 40% acid solution but probably the better buy). Glennster uses a 10 part water to 1 part phosphoric acid etcher to clean his rust off stuff. I probably mixed it at 5 to 1 for that little tank and left it for a day. Dumped it out and it left a little rust but most was gone from the bottom. Rinsed it out with water. Sprayed it down good with wd40 and swished it all over the sides and top of the tank. Didn't think about dropping something in to shake around to break up the rust.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
