Re: cub farmall ?????
Posted by screwstick on May 06, 2009 at 23:27:52 from (75.89.26.231):
In Reply to: cub farmall ????? posted by bodid1998 on May 06, 2009 at 18:19:40:
Solid. That (#6) is a key that will wear and get some play in it. Get all the play out of it that you can. Should be able to pull it straight out towards the carb after you remove the two bolts from part #5.
#8 will pivot inside the housing #20, with part #29 working against the shaft thrust bearing (#23) on one side and spring (#18) on the other.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
