Re: OT: What to look for in buying a used Excavator (Trac...
Posted by Randy-IA on May 07, 2009 at 14:54:09 from (207.177.83.117):
In Reply to: OT: What to look for in buying a used Excavator (Trackhoe) posted by charles todd on May 07, 2009 at 10:18:41:
I suppose I'd just check all the wear points on the boom and all the rollers in the track system. Turn it over the side and lift the track off the ground and turn the rollers by hand. They should turn pretty firmly with no roughness. They are usually sealed bearings but the ones I'm familiar with were serviced as a unit. Check for stretched tracks by looking at the hyd. tensioner if it has one. If it's fully extended then that's bad. Check for slop in the swing mechanism by swinging just a little and changing directions quickly but lightly. Check the swing brake
by swinging quickly and letting go of the control it should stop very quickly. Check for obvious cylinder leaks and fluid leaks in the engine compartment. Look at all the hyd. hoses. Make sure all the electronics work and work correctly. Most importantly try to use it for a day before you buy it to make sure the thing works well when it gets shook around and hot. Good Luck! ...Randy
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
