Not sure how others feel but I made up hydraulic hoses and adapters to hook up to a good tractor with hydraulic remotes. You need to remove rocker arms so all valves are shut all the time. (This good time to double check if valves are working.) Take out all spark plugs. Plumb the two mated cylinders (1&4 or 2&3 on Super C) together on one side of hyrdarulic remote and other pair on other side. This allows you to work engine back and forth. Also you will get lubrication from hydraulic oil. You get an even push on top of your piston and the force is greatly increased due to the surface are of the piston. Once it is free, crank the engine several times with plugs out to allow oil to blow out. Used this method on at least 10 engines. Little messey, but it works for me.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
