First thing I'd do is pull the shift lever and look to see that all of the three shifter rails are centered and lined up.
It sounds like the 1st-reverse shifter rail is slightly out of alignment. The ball on the end of the shift lever gets worn after 60 years or so, and will slip out of the slot in the shift rail prematurely. Often this results in the tractor ending up in two gears at once.
There might be more to the problem than just that, such as the detent balls falling out of the shift rail, but what I gave you should be a good start.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
