Super C governor question
Posted by Etnfarmboy on May 09, 2009 at 18:26:21 from (75.138.168.240):
I have the governor off of a Super C. It seems that the gov is "sticking". The previous owner had wired a spring to the carb linkage to pull it back to idle position. When I took gov off and inspected (mind you I am not a gov expert) it seems the speed change stop had worn or corroded to the point that it let the gov rockshaft rotate back to the point it was catching on the backside of the pin. Secondly there seems to be quite a bit of side to side movement in the rockshaft shaft. How much play should it have side to side? And lastly what else do I need to look for as a possible issue? The gov spring seems to be good and have good tension. The gov bumper spring was rusted and fell apart while cleaning. Thanks for any input.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
