Posted by farmerhr on May 09, 2009 at 20:21:26 from (64.12.116.73):
I am installing a wide frontend on my Farmall Super M. The drain for the radiator comes straight down through a piece of three eights inch pipe six inches long. I have to reroute the drain since it would go right through the front bolt hole that holds the pivot casting to the adapter plate on the right side. I need all four bolts to be used for the pivot casting. The bolts are three fourths inch thick.
What is the best way to reroute the the radiator drain ? I would like to be able to drain the radiator without disturbing the adapter plate, pivot casting etc. I do not have access to a Super M with a wide frontend on it to see how other people or the factory handled the problem.
I am not opposed to drilling an additional hole in the adapter plate. It is about five eights of an inch thick.
I am mounting the wide front end in the short turning position.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
