NAPA was closed so I borrowed a neighbor's 11/16 (0.02 in. less than 18mm) tap and ran it through. Compression meter fitting now bottoms out as does spark plug. #1 compression now 150 psi, same as the rest so this is not a valve/ring problem. Tractor smoked a good 20 minutes after cranking while all the crude accumulated in #1 cyl burnt up.
Cranked it again last night (in the dark) and could see some sparks jumping around #1 plug wire (arcing to neg pole of coil where it was touching) and at #2 plug. When I shut it off I was still seeing light between #2 plug and wire cap and I think I heard crackling (faint). I'll have to replace some wires later this week. I also think insulation on the pos/neg terminals of the coil would be in order. Still, tractor sounds much better.
In summary, the problem was in the ignition system (loose electronic ignition pick up, and SPlug wiring) and a cross threaded spark plug preventing it from seating. Cross threading might have happened during the trouble shooting. I'm going to be looking for better wiring. The little brass crimp on fittings at the distrib end of the plug wires are really cheap. Any one know where to get some good heavy duty SPlug wires?
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
