Posted by spiffy1 on May 11, 2009 at 07:28:19 from (70.41.137.72):
In Reply to: 10-20 steering posted by Bob on May 10, 2009 at 10:46:04:
I have the 15-30 set-up stuck in my head right now [which didn't have the offset to tighten the gears like a 10-20] but if the worm is less than half the problem - you may be able to treat it like a 15-30:
remove the linkage arm, remove the shaft assembly and turn the shaft 180 before reinstalling the linkage arm. If that was already done once [and now with the 15-30 brain block in my head, I may be wayyyy off], it still likely leaves you with 2 more spots as the wear happens more in a 90 (actually probably more like 30!) degree area, but bolt reliefs were not provided in the perpendicular directions so if you grind in bolt reliefs and you may be good to go twice more.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
