can't start my TD-9 on gasoline - suggestions?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Loren Pribyl on April 10, 2000 at 19:25:12 from (209.105.50.96):
I have a TD-9 (same engine as WD9) that refuses to start on gas. I went through the carb. and it's getting gas, it has spark, valves & linkages are working, but it doesn't give any indication that it's firing. It does puff some smoke as it's cranked over. I can pull-start it on diesel and it runs fine on diesel. It started good on gas until two years ago, when I had a small gas line fire that burned up the wiring and distributor cap. Since I replaced all that it hasn't worked. Does it seam like a timing problem in the distributor? I'd appreciate anyone's comments or suggestions, since it's tough to find anyone around anymore that has worked on these things.
Post A Followup
: Re: can't start my TD-9 on gasoline - suggestions?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
