About all you can do is pull the brakes off and housing holding bull pinion in and see what that bearing looks like,and if it is ok, take enough shims out so shaft doesn't have and up and down movement but with no amount of load on bearing, then replace seal. If you have bearing and or gear failures you will find filings in the hydraulic filter.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
