Had this happen with a 1456 found out that the camshaft key was very wore and was causing the valve timing to be off. To check this remove the valve cover and rotate the engine until a exhaust valve is about half way open and then rotate the engine in the oppisite direction. The valve should travel the oppisite direction instantly with no hasatation. If there is any hasatation there is a problem. To ratate the engine remove the inspection cover at the flywheel and you should be able to use a screwdriver or plybar on the ring gear. Good luck chucky
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
