Re: outer axle bearing on H sealed side in or out?
Posted by Owen Aaland on May 13, 2009 at 22:54:46 from (65.165.246.54):
In Reply to: outer axle bearing on H sealed side in or out? posted by rustred on May 13, 2009 at 20:27:45:
rustred said: (quoted from post at 20:27:45 05/13/09) the open side goes to the grease or oil, that should be easy to figure out and remember.same with your seals lip to the oil.
Ah... but not so easy to figure out in this case. The inside of the bearing is exposed to oil from the rear frame. The outside of the bearing is exposed to grease from the grease zerk. The shielded side goes in so that the grease can get into the bearing on the open side.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
