Unfortunatelly , the melting of the fuse block is a common problem. Too many lights on tractor for that style of fuse holder to handle and same for the cab relay which is the other problem fuse. Co. recommended repair is remove fuse holder, locate affected wire, cut them off and install circuit breakers. 50 series were same only harder to work in that area due to the sentry being mounted in there. As far as replacing the fuse holder assembly itself, it is a real night mare and you may have same problem all over again. Short circuits will pop a fuse right now, where as a heavily loaded circuit will over heat the contacts fuse fits in and eventually melting it out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
