Re: Grease fittings
Posted by Owen Aaland on May 17, 2009 at 23:25:28 from (65.165.246.54):
In Reply to: Grease fittings posted by Hugh MacKay on May 16, 2009 at 13:15:49:
Hugh MacKay said: (quoted from post at 13:15:49 05/16/09) Roy: The manual actually calls for grease every 500 hours of operation or every 6 months. It calls for several strokes of the gun.
The one on the distributor shaft has a hole on the back side opposite the fitting. On that one when you see grease coming out that hole, you have enough. That one will put grease in the distributor if you go too much.
The fitting on the distributor drive gear housing can put grease in the timing gears and on to the crankcase if too much is used.
Harold is right, if you have yahoo's greasing, best to stick with plugs. If you alone, choose your method.
Actually the front zerk is the one that will put grease into the distributor. The distributor housing has a groove to allow the grease to go around the outside of the bushing and any excess is expelled out the hole in the back. It uses an oilite bushing where grease is absorbed into the bushing material to lube the shaft.
Over greasing the front zerk will force grease along the distributor shaft on the inside of the distributor bushing.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
