806 Brakes....
Posted by Dan Swanson on May 18, 2009 at 10:53:29 from (63.172.252.199):
In Reply to: Re: Hey Tractor Vet, or anyone else... 806 Brakes.... posted by the tractor vet on May 18, 2009 at 05:54:29:
I took the brakes on the right side apart last night and they are dry and clean, there is no oil down by the drain hole on bottom of either cover. The self adjusters are both free. Could you tell me how to set the self adjusters for the initial setting? It just doesn't seem to be getting any pressure to the valve body. Is there a plug or something I can remove to chech for pressure or bleed the valve body. I know it is under extreme pressure of course.After thinking about it, where both brakes act the same that it is a pressure problem before it gets to the valve. May be I need to get a book that goes into it farther. Thanks for the Help! Dan
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
