I have a plain M but I believe the setup is identical to that on a Super M. I had to go out and buy what is called an "offset" or "obstruction" wrench from NAPA to get at that back nut. It is shaped like a "C" and allows you to get around things that might be in the way of getting at a bolt.
Also--I found you have to be careful with lining-up the tube that comes from the governor to the butterfly shaft on the carb. If it binds in anyway you will get a sticky throttle response. I attached the carb first to the manifold with the nuts kind of loose, then connect the gov. to throttle tube to the carb and tighten the screws. Then tighten the carb stud nuts.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
