Re: 263/264 engines
Posted by Owen Aaland on May 19, 2009 at 14:16:37 from (65.165.246.54):
In Reply to: 263/264 engines posted by chester5731 on May 19, 2009 at 10:53:29:
chester5731 said: (quoted from post at 10:53:29 05/19/09) I have a friend with a buckeye super d trencher. It has an IH 263 gas engine that froze and cracked the block. Is there much difference from that to a 264 out of a 151 combine?
The blocks are different. They can use most of the same gaskets but most of the internal parts are different. The BD 264 is sleeveless. The C 263 may or may not be sleeveless. The C 263 is an ag/industrial engine. The BD 264 is a motor truck engine.
The rear of the engines will interchange but the front mount will most likely be different. The governor may be the biggest issue. The ag/industrial governor mounts parallel with the engine block. The truck engine mounts perpendicular with the block. If you can get around those issues it should work.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
