Re: crank case oil contamination
Posted by Janicholson on May 19, 2009 at 17:19:16 from (66.173.50.20):
In Reply to: crank case oil contamination posted by Carl Naylor on May 19, 2009 at 03:52:13:
You are correct. Seal on the input shaft is probably bad. Set the engine up on #1 TDC compression before taking things apart. Mark the distributor location to retain timing. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
