The system you are working with is the added crankshaft driven hydraulic pump. The relief valve is in the end plate of the valve stack. If you add any valves to the return line you must also add a relief valve because the one that is there now dumps the relief pressure internally to the return hose port. It cannot provide protection from any obstruction (such as another valve assembly) from that port to the reservoir.
The easiest is a mentioned earlier, just add to the valve stack with the same type of valve and use longer bolts. You can add as many as you have room for.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
