Posted by CNKS on May 24, 2009 at 18:25:14 from (216.144.104.128):
In Reply to: Farmall C smokes posted by bigr on May 24, 2009 at 18:15:27:
10 wt was recommended before IH developed Touch Control fluid, which was then replaced with Hytran--so 10W will work, but I prefer Hytran. Blue smoke is oil, black smoke is a rich fuel mixture, white smoke is a water or antifreeze leak, possibly a cracked head or block. If the spark plugs are black and sooty the mixture is too rich, if oily it is burning oil and needs at least rings, preferably a complete overhaul including the head. Could be a combination of all of the above. Run a compression test -- you will likely find a lot of variation between cylinders. Compression should be 100+, new was about 120, will run on 80. Ideally cylinders should be within 10% of each other.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
