I would use a squirt oilcan to fill the galleries and oil filter. Just use a rubber tube to connect to the oil pressure port on the engine, and pump several oilcans full into it ( you will feel it become filled when pressure on the oilcan trigger increases ) Polarize first engine off, then just leave the key off and plugs out when cranking. It will have pressure almost immediately if you precharge it as above. Then start it. Run for 15 minutes, then retorque the head and set the valves again. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
