Posted by Dave in CT on May 25, 2009 at 07:16:14 from (69.182.86.5):
Hey all,
I've borrowed a neighbor's 2-bottom plow. It might be a JD but it's had some of its hardware removed. I've got it hooked to a homebuilt 3-pt hitch (probably modeled after a saginaw) that has two lift cylinders and I have a third cylinder serving as my toplink. All cylinders are one-way, lift only.
This is the very first time I'll be using a plow, period. I don't have any tractors to look at as an example so I'm turning to you folks. I only have to plow enough for a garden plot - 40 x 20. Can I plow with this without screwing up my 3-pt hitch? I would imagine I need to hook up some sort of side stay to keep the plow from tracking to the left, following the direction of the plow points. If I run a stay from the right side lift point on the plow to the right of the 3-pt hitch (near where the base of the right lift cyl is attached there looks to be a bolt hole for this purpose) it looks like I'll hit the side of that right lift cylinder. It does look like I can slide the whole plow rig one way or the other on the bar that goes between the two lift points.
This is also my first time putting up a post with pictures so I hope they show up - apologies if you're looking at nothing.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
