Posted by Haas on May 27, 2009 at 13:43:54 from (12.65.6.139):
In Reply to: rear end oil posted by Reel on May 27, 2009 at 13:11:23:
I wonder if you realize, that there is an inner and an outer seal on the axle housing. The axle housing has to be removed from the tractor to replace the inner seal. The outer seal is only a grease seal as the outer bearing is only lubed with grease and there is not supposed to be any oil out at the end of the axle. The inner seal is near the transmission housing and keeps the oil in the transmission and out of the axle housing. So...if you just do the outer axle seal, it probably won't cure the leak. I have a C which is similar and I have resigned myself to live with the leaking axle seal. Some grease in the fitting for the outside bearing will help reduce the leak.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
