340 won't start
Posted by Chuckle on May 28, 2009 at 07:18:53 from (71.253.69.246):
I bought a 340 gas about a year and a half ago. The engine was rebuilt before I bought it (less than 100 hrs) and it ran fine when I loaded it and unloaded it. I partially disassembled it to fix a few hydraulic leaks and to repaint it (mostly just sheet metal and the hydraulic pump). I finally put it back together and other than a new rotor distributor and plug wires everything was the same as when I took it apart. However, it won't start. I changed the points and condenser and the plugs, it is definitely getting spark. It seems like a fuel issue. The carb (a Zenith) was put on just before I bought it. I tried using starting fluid, I even pulled the plugs and put gas in the cylinders. It seems to sputter but won't fire up. I ran a compression test on it and cylinders 2,3 and 4 and they were all around 130 lbs, however number 1 was around 90 lbs. I wouldn't think this would cause a starting problem, but I could be wrong.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
