Re: Throttle Lever Problem on Farmall M
Posted by Roy Ward on May 28, 2009 at 12:32:36 from (66.82.9.54):
In Reply to: Throttle Lever Problem on Farmall M posted by Melvin Ware on May 28, 2009 at 09:19:35:
I did notice you can buy the pin that has a nut that bolts threw the handle and also the top cap. But I did what GeneMO did. I used a brass rod to build it up. I had also some worn teeth on the cap so I used dremel with a small cutting wheel to square them up.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
