I suspect that name on the valve is "Gresen, Minneapolis". They were a very common valve used in the 50's and 60's. I do not know if they still exist, but maybe Google will tell.
I have not had good luck with the advice or product from Northern. Very few (if any) of their people know hydraulics, and they have become a competitor for HF with a huge amount of import stuff.
Your loader is not made by Gresen, but may be a Superior loader. They were common and fit these tractors quite well. Any good hydraulics shop can get you a replacement valve (2 spool & 2 control levers, if you have the tilt bucket. You will also need to know whether you have 2 way cylinders allowing power down on the boom...ie. can you pick up the front wheels with loader power?. Some valves can be adjusted to provide one way power for one spool and have 2 way power for the other spool. And some have no such adjustment, so they must be spec'ed correctly.
Most Gresen valves were good quality and possible to rebuild with new "O" rings on the spools. But it may be scored internally in the spool bores and not saveable.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
