Thanks to all of you guys for your response to my throttle lever problem. After reading your suggestions I did a visual check and think I see where the problem is. Mine has square notches on the fixed throttle plate (rather than saw tooth) and a rectangular cog on the throttle arm, which is designed to engage these notches. I found the cog is badly worn in the center where it engages the notches. Also, the leading edge of the notches are rounded where the cog rests against them - either due to the throttle lever slipping or being pushed to a lower speed setting. Hence the cog can no longer get a good "bite" into the throttle plate notches. I noticed the "cog" is a replaceable part, so does anyone know where I might order one without buying the whole "kit and caboodle"? If not, guess I'll have to build it up with weld and grind it to the original shape to fit the notches as several of you suggested. Also, where the front edges of the notches are rounded off may need to be "squared up" as someone suggested. However, that will increase the width of the notches so I may do that only if needed. If these two measures don't totally fix the problem, then I may need to address the vertical play in the lever, estimated to be about 1/2 to 3/4 inch, and could be due to a worn bushing and/or weak spring. Thanks again!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
