Does it rev up ok in neutral and hold steady at high idle speed of 2000 to 2400 rpm? I may not be the most qualified here but I would think check the air intake pre-cleaner for restriction and oil level in the bath, then I would say something with the injection pump perhaps? You can check compression through the glow plug holes should be around 350 psi but I doubt if it would be that. Good luck.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
