Posted by Doug - Iowa on June 02, 2009 at 05:32:24 from (71.32.179.33):
In Reply to: Help ID Older Hayrake posted by Illinois Farmall on June 01, 2009 at 19:53:51:
That would probably be a IH #10 rake. Very dependable and easy to work on, at least in my experiance. The gear box will gather water, be sure to drain it and change the lube every spring. Mine leaks a bit so I use corn head grease for lube.
#13 and #35 are simular but you said the shaft went from the sproket to the gearbox, which should make it a #10.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
