Fuel is getting TO the carb., but is the fuel getting INTO the carb?
Take it apart, remove and clean the float valve with spray carb cleaner, blow it dry with compressed air and reassemble. Double check the float height setting and also that the float moves freely.
I guess that IF the load adjustment screw is turned all the way in, which it should NOT be, then NO fuel can get into the main stem, and the tractor will not run.
The load screw should be set at 3 turns out (factory initial setting), and the idle/air adjustment screw should be set a 1 1/2 turns out (factory initial setting)
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
