If the noise started when the TA was replaced it is possible that you have gears that mesh together that do not the the correct tooth angle. Originally this series transmissions (starting with the 706/806) were made with gears with 20 degree pressure angle on the teeth. A change was made to 25 degree teeth to eliminate some of the noise. Running one of each will cause noise.
It is also possible that the MCV was installed with the thin gaskets when it need the thick ones. That will cause the hydraulic pump gears to be too tight.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
