If it's the former forget about a 12 volt generator! An alternator does better job keeping the battery charged, provides more power for lights, etc. and will last longer/require less maintenance. It’ll also be cheaper than a generator.
Tip: Use a 3-wire rather than a single wire alternator. A 3-wire requires a few more feet of wiring plus a warning light or diode. But it will be cheaper and it will avoid the annoying issues single-wire alternators frequently seem to suffer from.
If you elect to stick with a generator most any Delco generator from a tractor or GM car from the late ‘50’s/early 60’s will work (IHC, Deere, Case, MM, Oliver, etc). You might need to reuse the fan/pulley assembly from your 6 volt generator however. Make sure you get the matching regulator too – otherwise the smoke may be let out of the generator!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
