Easy to install,sounds a little weird, but works. Install the alternator upside down. The narrow alt. ear is now the bottom pivot. The wide ear attaches to the top bracket. That solves the belt alignment issue. You might need a washer or two on the bottom bolt to get perfect alignment on the belt,but its very close. On the top bracket I had use a 3 inch piece of flat stock mounted straight up on the original bracket bolt in the engine Then drilled a hole in the top of the flat stock to attach the original mounting bracket to that. That gives you elevation on the top bracket to deal with the larger diameter body of the alt. Sorry I can"t supply a picture.[dead camera] but mine has been mounted on my 340U for 20 years like that,trouble free. Note: this is with a 10si, I am not sure a 12si will work quite the same.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
