No one can vouch for the integrity of a manufacturer's gear, except the seller, and they warrant the product. A used gear has no warranty. That said, I believe in good used gears for that application. The Key would have been nice if it sheared, but it is not designed to shear. it is not a mechanical "fuse". It was designed to carry as much torque as the gear teeth could supply, and that was probably 60 to 70% of the maximum expected momentary pressure applied.
The limiting factor is the pressure relief valve on the hydraulic system. If that has been tweaked, or is stuck closed, it will cause breakage. I would use a used gear from a later model tractor that is number compatible with the gear in yours. The caseih.com site has parts diagrams that show the highest compatible gear number for replacement. If in doubt, look at IH 200 and 230 tractors to see which gears they spec for use. JimN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
