Posted by ih5088 on June 05, 2009 at 18:47:57 from (70.217.59.142):
In Reply to: Dt466 into 1066 posted by I.H.parkingonly on June 05, 2009 at 18:03:46:
To swap a bus or truck engine, you need to change the rear adapter plate, oil pan and sump, (you can use the truck pan but it makes it hard to get to the bottom bolts on the frame rails), the front cover, exhaust manifold, oil filter base and fuel filter base and lines, the governors in the injection pump are also different so you should technically use the pump off the the tractor but the truck pump would work, I might of forgot a few things but I hope this gives you an idea, it isn't just a quick simple swap
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
