Posted by Brownie 450 on June 08, 2009 at 13:50:22 from (216.51.158.172):
In Reply to: farmall c not running posted by Eric Phipps on June 08, 2009 at 11:37:25:
How is the wire from the switch up to the coil?? Also the switch itself?? When it starts to die next time, pull the choke out a bit to make sure fuel delivery isn't the problem. If it still dies, connect a jumper wire from the battery hot terminal to the coil primary terminal that comes from the switch. If the engine starts/ runs, look for a bad wire/ terminal/ switch. Something is not making the connection in the electrical department, & you have to isolate which area is causing trouble. These systems are not that complicated.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
