Posted by karl f on June 09, 2009 at 07:13:03 from (209.188.106.159):
have a customer with an externally regulated motorcraft alternator. He bought a "one wire conversion" kit from us (it"s really a mini sized external regulator made by Victory Lap that bolts on back). If it was a street car, tractor, or similar i would not have a question; but this is a drag car that needs an emergency shutdown master switch accessible at the rear of the car. The battery is already at the rear.
I want to help him wire the switch correctly so that in worst case scenario--with the engine wide open and driver passed out--everything will kill yet at the same time prevent the alternator from being damaged during what he calls "tech" where they sometimes pull the switch to test that it actually works. Right now he has a single pole master switch with only 2 terminals on it. Being a race car, i bet he spent big money on it, so if there is a way to do this with that swich, he"d probably like to go that route. If not, what is/are the other option(s)?? quick note about the regulator kit, all the wire connections are external, easy to get at, and have a few inches of wire coming out of the regulator, so any connection that needs to be modified can easily be changed.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
