Posted by Rootsy on June 12, 2009 at 10:45:16 from (24.247.111.162):
In Reply to: Farmall M overhaul posted by John Shipley on June 12, 2009 at 10:14:13:
going sleevless is going to require a trip to the machine shop, some pistons from one of the custom places and a few other items more commonly used by pullers in big inch engines...
If it is a 248 block you can go with 4" ID liners and get 264 CID.. if it's a 264 motor you can go to 4 1/8 overbore liners and get 281 CID...
Also have the option of doing a stroker assy...
All it takes is $$$ above and beyond a regular rebuild kit...
To run on E85 I would recommend the highest static CR you can get and eliminating all rubber in the fuel system. Carburetor will need to be recalibrated also. You can do a few things to get some power back out of the fuel swap but it isn't nearly as easy as playing with a SBC etc...
This post was edited by Rootsy at 10:49:38 06/12/09.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
