The problem may be the coil with the heavy contacts (cutout relay) it has a pull in winding with fine wires, and a heavy current winding with thick wires. If the pull in voltage is too high with the cap on, it will not pull in. Thus just barely weaken the spring on that relay so it pulls in a bit easier. The other coil adjusts the voltage when charging. If you have been making it tighter, that is not the answer. You may need to put it back to where it was. If when you loosen the other (cutout spring) too much, it will not cutout when the tractor is shut off, and the tractor will then discharge the battery rapidly into a smoking generator. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
