With a on off switch to the alternator "excite" terminal, (assuming you shut that switch off when the tractor is not running) the tractor seems to be wired OK. (I prefer either a parking light bulb (filament type not LED), or a diode in the excite wire because it is convenient. The most likely problem is the internal diodes in the alternator. If one of these has gone bad, it will pass current in the wrong direction letting the battery go down. The remaining diodes will work well enough to charge the battery when used. Use a multi meter with a built in amp meter as follows: Disconnect the alternator big wire. Set the amp meter on its highest amp setting (you may need to move a lead to a different spot on the meter) connect the amp meter leads with the black on the post of alternator and the red on the wire you disconnected. The reading should be less than 150 milliamps. You may need to adjust the meter settings to get an "in range reading". 1000ma equals one amp, so 150 milliamps equals .15 amps. If it is more like one amp, the the battery will drain in approximately 50 hrs (this depends on the battery and is not a hard number) If it is less than the 150ma, the diodes are OK. A battery with a cell going bad can also self discharge. This mimics the situation you have. Even new batteries can be bad. JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
