Posted by J.J. from Afton on June 15, 2009 at 19:57:25 from (66.41.82.17):
In Reply to: 340 HELP posted by Tracks on June 15, 2009 at 08:47:22:
I may be wrong but I do not believe that the ball is sold seperate from the axle least not from the dealers. The likely reason they didnot use a nut to hold the ball on is that over time it would wobble or rattle off. The cap holds the ball from going side to side and being pulled downward becasue the weight and movement of the tractor on the axle pushes the wishbone up and back for the most part. As for the ball I believe it is only prssed in likely when the axle is hot and expanded hence why it is not welded. So you will have to try heating around the pin to see if the ball/pin will be able to driven out or pressed out or you may have to replace the whole main piece of the front axle.
Is there any chance that you could post a picture or two of the ball/cap you're talking about?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
