Re: Generator belt tightening
Posted by Janicholson on June 17, 2009 at 07:00:12 from (66.173.50.106):
In Reply to: Re: Generator belt tightening posted by Janicholson on June 16, 2009 at 22:14:51:
It is painful. The Big fan belt must be removed first. That requires the adjusting to loose of the water pump pulley Spray it with penetrant, and remove the setscrew entirely (allows penetrant to get to threads better) Then use a brass or very soft iron drift punch to tap (in both directions on the setscrew boss, (and the opposite side) to get it moving. Wire brushing the exposed threads is also good.
When putting it back, do not over tighten, It should have and inch or inch and a quarter slack when pushed and pulled on one side of the big belt. Too tight just ruins water pump bearings.
The Big belt does not need to be removed entirely over the fan blade tips (a struggle) just weasel the old belt under it, and new back on (again under it on the WP pulley. Good luck with the fan pulley. Be gentle, they break. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
