Re: Source for this valve?
Posted by Janicholson on June 17, 2009 at 07:24:43 from (66.173.50.106):
In Reply to: Source for this valve? posted by Mike CA on June 16, 2009 at 22:10:57:
Unless the threads are stripped, the valve you have might be good to use. I say this because it looks (from the photo) that the valve has been both soldered, and brazed into the tank. The solder (silvery color) looks to be on the fitting in the tank, to the tank. The braze looks to be on the valve to fitting. If so the solder will melt first and leave the fitting on the valve. If the valve is leaking, it might be easy to have the needle (turnable part) machined in a lathe to make it new.
Good luck, JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
