Posted by mattofvinings on June 18, 2009 at 16:45:53 from (198.208.159.20):
In Reply to: 340 utility posted by mattofvinings on June 18, 2009 at 10:01:41:
Thanks Hugh, the only basic change I can see from reading/searching is that the 340 has a 7.6:1 compression ratio vs. the 5.?:1 ratio of the older "C" iron.
While that change might be partly done with a new cylinder head chamber design I'm not so worried about the head....its the block and crank depending on what got trashed during this low-lube event I've heard about. If it is as simple as getting a good SC block and lower end and using the 340 sleeves, rods, pistons and head, I'm there :).
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
