Normally I would say this is the typical stuck in two gears at once problem. However, 1st and Reverse are on the same slider gear.
You can't be in 1st AND Reverse at the same time unless something is really really wrong in the transmission.
Are you SURE that it's 1st gear you're shifting into? Could it be 3rd?
I guess it wouldn't hurt to try the stuck-in-two-gears-at-once cure. You need to remove the shift lever, and look down in the hole. There's three shift rails in there. Use a big screwdriver to pry all three back to center.
The ball on the end of the shift lever is worn after 60 years of use. You can build it back up with weld and grind it down to fit.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
