Re: pop in trans
Posted by Janicholson on June 19, 2009 at 18:30:18 from (66.173.50.77):
In Reply to: pop in trans posted by cazzhrdwd on June 19, 2009 at 17:10:02:
The term spinner is not (in my history) associated with anything on the trans. I'll guess it is the belt pulley drive gear attached to the top of the torque tube. With that assumption, the gasket can be made, or purchased (CaseIH probably has them. Use the same thickness as was on it due to the fact that it is the method of setting gear clearance to the drive.
The threaded components are actually dowels used for assembly at the factory, and afterwords when taking it apart. they will not tighten, they will just pull out. The bolts you actually seek are inside. Remove the cover plate to the rear of the belly pump (tin plate, no oil in there to speak of, it is a dry chamber). The bolt heads can be seen from there. I would jack the trans up to take out the gap then tighten the bolts.
This is not a gasketed mating surface, so there is no gasket there. caseih .com select US, then parts and service then parts, then begin your search right here, then put in Farmall, then select M, then select chassis. Many pictures! JimN
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
