What I would look for next is what happens when you give the steering wheel a slight "crowd" in either direction with wheels fully engaged with the ground.
What I would expect is pump pressure would rise as the spool moves and forces the boost/assist cylinder to move, then as the spool re-centers, the pump pressure would then drop back to zero (open-center/spool-neutral condition).
Another mental abstraction to think about (or from the viewpoint of) is that the system doesn't exactly "demand" pressure in my thinking. In retrospect, it "creates" backpressure (what the pump-output gauge is reading) by virtue of creating an effective restriction to fluid flow or presenting the ever-adding positive-displacement volume of fluid against a mechanical load (as in the case of a hydraulic cylinder).
Just a practical example of above, with a functioning system I would fully expect pump backpressure to be significantly lower when turning the tires on a film of slick mud vs. when they are half-buried up to the axles. In other words, even though the pump can produce 1400psi when thoroughly dead-headed, the pressure is "matched" to the mechanical "resistance" load applied in the opposite direction.
This post was edited by mattofvinings at 16:41:34 06/20/09 3 times.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
