Posted by pete 23 on June 20, 2009 at 20:43:45 from (173.87.14.132):
In Reply to: Super H Carb question posted by jonnny2006 on June 20, 2009 at 15:18:34:
The original high speed, load main jet, is calibrated for full load operation and the intention of the adjustment screw is to slightly decerease fuel flow for light loads. You should be able to kill engine off screwing it way in when running at full throttle. Some screws are actually too short to fully contact main jet seat. This can easily be observed if you have carb bowl off. Screwing all the way out will only increase fuel to the calilbrated size of the main jet, however, over the years of these tractors any modifications could have been made. I have seen them drilled out to about 1/16th inch and gas will go through like a house a fire. Another thing is that some of the increased power packages had a main jet in pkg with a different degree taper on the seat and the original adj screw did not fit it properly. You need to change the screw and seat together. Fire crater packages were that way.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
